Re: Super A gurgling sound after shut-off
Posted by Trent544 on November 23, 2007 at 17:15:24 from (166.82.246.61):
In Reply to: Super A gurgling sound after shut-off posted by ddg on November 23, 2007 at 07:36:16:
It's the oil gurgling in the air cleaner when the engine rocks over backward. Perfectly normal if it's not knocking and running backward. Try taking the oil cup off the air cleaner, start and stop the engine and see if it happens.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
