Re: Can I jump a 6v with a 12v?
Posted by Yellott canby on November 23, 2007 at 17:47:04 from (4.225.101.186):
In Reply to: Can I jump a 6v with a 12v? posted by Mike CA on November 23, 2007 at 17:38:08:
Hello,
You can turn a 6 volt starter with a 12 volt battery, my '41 H is that way. If you are just cranking the engine, I would unhook the 6v charging system, from the start system. In other words don't let the 12 volts into the generator and regulator.
Good Luck, YC
