Re: Can I jump a 6v with a 12v?
Posted by Hoss in Maine on November 23, 2007 at 17:55:43 from (72.224.133.167):
In Reply to: Can I jump a 6v with a 12v? posted by Mike CA on November 23, 2007 at 17:38:08:
Mike,I wouldnt you could blow the 6volt bat all over you and everything else.Put a 12 volt bat in it and fire it up.Dont churn it too long or starter will get too hot,you can tell.If youve got a mag youre all set but with a dist dont run it long or youll burn up coil and or points.If you want you could put a ballast resistor between coil and ign switch and run her forever that way.Later Hoss
