Mike, jumping 12 volts into 6 can be very dangerous. Last time I tried it there was an almighty explosion when I touched the jumpers to the 6volt battery. All that was left of it was the base and the terminals on the ends of the cables. Fortunately I was not hurt. When the higher voltage goes into the lower voltage battery, it rapidly generates lots of hydrogen gas. Any spark from the cables and you have yourself a hydrogen bomb with sulfhuric acid as a bonus. Same basic rules apply when jumping anything: always hook up the dead battery first and ground to the frame or the block, not the battery. I would do as the others suggest and simply stick in a 12 v battery to get it to go. The 6 volt systems are fine if everything is in good shape. I started my Super A today after sitting since June. It was 2 degrees out and it started on the third compression. Just my 2 cents Karl
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
