Re: Can I jump a 6v with a 12v?
Posted by Al L. in Wisc. on November 23, 2007 at 18:25:28 from (207.190.67.77):
In Reply to: Can I jump a 6v with a 12v? posted by Mike CA on November 23, 2007 at 17:38:08:
Mike, you stated no battery in tractor so, yup, you can do it. Don't have anything on and you can jump directly to the starter. Tractor out of gear and even blocked in case the clutch would stick. Keep polarity the same, make the connection on the starter terminal and finally to the vehicles frame. This will cause less arching damage to the starter terminal and you won't have sparkies flyin' next to the battery. Best to have someone out there w/ya if ya can.
