Re: Engine rebuild questions for an F-20
Posted by SproutW on November 23, 2007 at 19:14:39 from (64.4.162.236):
In Reply to: Engine rebuild questions for an F-20 posted by Scott Rukke on November 23, 2007 at 19:07:18:
I always used a block of wood and a 2lb hammer. You tap them up from the bottom. You only need to tap them a few inches and you can pull them out the rest of the way.
