Re: Can I jump a 6v with a 12v?
Posted by John T on November 23, 2007 at 19:58:47 from (66.244.83.147):
In Reply to: Can I jump a 6v with a 12v? posted by Mike CA on November 23, 2007 at 17:38:08:
IT DEPENDS Its muchhhhhhhhhhhhh safer if you simply jump the STARTER ONLY (if switch and wiring type permits the same) without backfeeding 12 volts back into a 6 volt electrical system.
I WOULD NOT JUMP A 6 VOLT BATTERY WITH A 12 VOLT it could blow up.......
Keep polaritys matched..............
If theres no tractor battery at all and its a battery/coil ignition if you run it at straight 12 volts for too long the coil will overheat unless you add some external series ballast but if its a mag its not wired to any battery power.
John T
