Re: 6 volt system, has a 12 volt coil
Posted by old on November 23, 2007 at 21:18:28 from (4.244.221.127):
In Reply to: 6 volt system, has a 12 volt coil posted by MikeK on November 23, 2007 at 20:15:32:
Well it could be that it has a 12 volt coil which needs a ballast resister and if so then would you believe the coil is really a 6 volt coil. Most coils will say right on the external resister need or something about no resister need
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
