Mike: There is no problem jumping a 6 volt system with 12 volts. I always go directly to starter with the jump cables, and don't activate your starter switch. Just hook positive terminal of car to the tractor frame, then boost by touching car negative cable to input of starter bypassing the solenoid. The big concern here, you are bosting a positive ground system on tractor with a negative ground system in your car. Basically you hooking the positive side of your cars system to the frame of your tractor, thus you can not let any part of the car touch any part of the tractor.
I've boosted 6 volt tractors many times over the years, had one mishap. One end of a steel cable on the tractor accidently dropped on bumper of car as I was boosting. Belive me it was quite an explosion, there was nothing left of cars battery but the base.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
