It won't matter, but there's no way another quart and a half will fit in the reservoir. If it would, then it'd be a 7-1/2 quart reservoir not a 6 quart, right? :)
What's going to happen is, the excess oil is going to squirt out the vent in the cap and go EVERYWHERE!
You need an external reservoir to supplement the factory liftall. 2 gallons should be plenty, because you don't want the pump to run dry. A 2 gallon tank won't be that expensive and should tuck right under the gas tank.
Just remove the vent cap from the H, hook a hose from the drain in the 2 gallon tank to the fill pipe, and mount the 2 gallon tank above the belly pump so the extra oil can drain into the belly pump when it needs the extra oil. No valves necessary, it's all automatic.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
