Excellent, as an aside, on some makes of tractors that used a saddle starter mount mechanical push to start switch instead of an electric solenoid, the ballast by pass feature was achieved by an extra lil small terminal on the side of the starter switch which was hot ONLY while the switch was engaged. A lil wire was ran from there up to either the coils input or ballast output terminal (same ponnt electrically)......... Sooooo many of those got disabled over the years either cuz the wire got left off or disconencted or else the switch was replaced with one a lil cheaper that lacked that extra lil side terminal.....
As you well explained, that feature could really improve cold weather starting cuz when its cold the battery is less efficient PLUS the engine is harder to crank and the high starter current draw drops battery voltage drastically causing a weak spark WHEN YOU NEED IT THE MOST
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
