Re: IH 706 miss
Posted by ejr-IA on November 24, 2007 at 10:45:16 from (204.11.182.54):
In Reply to: IH 706 miss posted by Melvin Shaw on November 24, 2007 at 09:26:29:
Which cylinder is the miss in?It could be carbon under a valve or a burned valve.The exh. valves on two cylinders are next to each other and can burn between each other that can cause a miss between two cylinders they are 2,3and4,5 or maybe one cylinder with bad compression.
