Re: How much water?
Posted by Andy Martin on November 24, 2007 at 10:49:21 from (63.99.111.185):
In Reply to: How much water? posted by Mike CA on November 24, 2007 at 10:21:44:
About a half inch below the top of the radiator. Not the filler neck, the actual top of the upper tank.
As long as you have the top of the radiator core covered you'll be fine. The water pump will throw enough water up to keep it circulating.
