Posted by Andy Martin on November 24, 2007 at 11:14:15 from (63.99.111.185):
In Reply to: 560 and sleeves posted by Up North Louie on November 24, 2007 at 09:52:46:
It may only need valves and guides. You can do a compression test and determine if it need rings also. Do a compression test, then do it again with a couple of shots of motor oil in each cylinder and see if the oil seals the rings. If it does, you need rings too.
Rings are really cheap and if the cylinders look good there is no reason to change the sleeves, just remove the ridge and put new rings in. You'll get many hours of satisfactory service out of it for 20% of the money. Your cousin was just preparing you for the worst. You can rent a sleeve puller.
If it were me, I'd put in 20w50 oil and hotter plugs and enjoy it for a few more years.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
