Re: IH 706 miss
Posted by WRA on November 24, 2007 at 14:05:49 from (67.142.130.19):
In Reply to: IH 706 miss posted by Melvin Shaw on November 24, 2007 at 09:26:29:
When you replaced the injector did you bleed it
off,to get the air out of the line and to be sure you are getting fuel to it.if so do a compression check.you may have a burnt valve or rings may be worn. good luck hope you get it going
