Re: Tricks for stoping a leaky valve?
Posted by glennster on November 24, 2007 at 16:31:45 from (68.60.242.156):
In Reply to: Tricks for stoping a leaky valve? posted by Mike CA on November 24, 2007 at 16:01:55:
bowl or valve leaking? if bowl gasket, remove glass bowl, be sure gasket is in straight, if its cork, you may need o replace it, be sure the sediment screen isnt in there crooked. if its the valve, try and tighten the outer nut (packing nut) a wee bit and see if it stops. in a pinch, (emergency farmer repair with incorrect parts) back the packing nut all the way out, put a couple wraps of teflon tape around the shaft and screw the packing nut back in. (i know the correct police 'll get me) p.s. dont drop the glass bowl, it breaks!!!
