Re: Tricks for stoping a leaky valve?
Posted by Armand Tatro on November 24, 2007 at 17:04:30 from (67.176.252.97):
In Reply to: Tricks for stoping a leaky valve? posted by Mike CA on November 24, 2007 at 16:01:55:
Be sure to give a slight spin to the sediment bowl as you tighten the locking nut to get the bowl to seat properly or it will leak at the gasket. You also need to do this with the oil filter canister as you tighten it or it will leak also. A farmer friend of my Dad showed me this trick years ago. Armand
