Dear Mike the solution is simple, and includes two steps if one fails to work, try the second. Using a pair of pliers wit tape on the jaws to prevent marring, tighten the valve (from where it is by finger) 1/8 turn tighter with the pliers. Then turn it back and forth at that place about 10 times. This seats the needle into its seat. Do not over do this, it won't take much to wreck it. If it still leaks, the valve and packing will need to be taken out. then a drill that fits nice down the hole is used to resurface the seat. If there is a groove in the needle, it should be resurfaced as well. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
