Re: 706 gas- what to watch out for
Posted by RustyFarmall on November 24, 2007 at 18:39:23 from (66.43.253.19):
In Reply to: 706 gas- what to watch out for posted by Dave from MN on November 24, 2007 at 17:11:26:
For the way you will be using it, gas will be better than diesel. It will run just fine on regular pump gas unless you are working the snot out of it, and then you would probably want to use high octane gas. There used to be a bunch of those 706 gassers around here, and there are still several if you know where to look. I don't know of anyone that was in the least unhappy with them. Just keep in mind how old that tractor is, and there might be some problems strictly because of age.
