Re: Tricks for stoping a leaky valve?
Posted by old on November 24, 2007 at 19:13:01 from (4.244.57.153):
In Reply to: Re: Tricks for stoping a leaky valve? posted by Mike CA on November 24, 2007 at 18:10:21:
The packing is sort of a felt or rubber washer sort of thing. Sort of like the packet glans on a ships screw shaft. Only way you can tell it is still there is to take the valve apart and then depending on what type it is you maybe able to repalce it or you may not be able to.
