Re: 766 gas -valve or ring
Posted by the tractor vet on November 25, 2007 at 06:46:09 from (76.212.229.0):
In Reply to: 766 gas -valve or ring posted by waterlooboy on November 24, 2007 at 18:48:06:
Well first off ya should ONLY RUN the low ash oil in the 30 weight and second ya HAVE TO run the 93 octane gas. So if none of the above has been used ya had pull the head and take a look see as you may have ate another valve due to the wrong engine oil being used or scored one or more sleeves due to the lack of the correct gas. or impropper ing. timing.
