If gas is leaking on floor, it would do that either with fuel needle valve ON or OFF, no? Sounds like the leak is AROUND the shaft. I don't know what the original packing is like, but I think, like some of the helpful people who wrote here, that some sort of plumbing packing might work. If you have ever repacked a standard plumbing valve by wrapping a little teflon plumber's packing OR the string-type of packing around the stem and then putting the nut back on and tightening a bit, you'll know what I mean (both types of packing sold in plumbing section of hardware stores), you'll know what I mean. Can be done in five minutes. Agree with others here NOT to tighten the fuel valve too much. If it is correctly shaped and smooth, it will shut off the fuel. Sometimes after years of wear, a groove gets cut in the tapered part of the valve, and there will be a leak through the fuel line, but this shouldn't affect the seal at the packing nut. Everything here is probably brass, and can take only so much pressure. This includes the brass nut that the packing would go into. Hope this helps a little. It is great how people share their ideas with one another here.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
