Posted by Wardner on November 25, 2007 at 10:31:28 from (4.154.246.73):
In Reply to: 560 Farmall fast hitch posted by Dennisn715 on November 25, 2007 at 09:22:53:
If Case/IH doesn't have them, go to MSC, McMaster-Carr, Graingers, or your nearby bearing house. You can order bushings/bearings on the internet from these sources..
I don't recall any brass bushings on a 560 hitch. If there are any bushings, they are almost certainly steel. I take that back. There may be brass bushings in the rock shaft arms. Parts subjected to heavy pounding/draft loads will be steel.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
