Re: 234 picker and 560
Posted by Janicholson on November 25, 2007 at 15:07:16 from (64.83.208.65):
In Reply to: Re: 234 picker and 560 posted by gene bender on November 25, 2007 at 13:31:22:
:-) Though it would cause more soft ground problems, the wt would not be on the housings/bearings, just the contact patch under the tires. JimN
