Re: Final Update- Ih 706 still no oil pressure
Posted by Janicholson on November 25, 2007 at 15:52:29 from (64.83.208.65):
In Reply to: Final Update- Ih 706 still no oil pressure posted by Shawn P on November 25, 2007 at 15:08:18:
The idea of using a garden sprayer to put oil into the system while looking at the underside of the crankcase/rods/and oil return holes will tell it all. A head gasket on wrong can put oil where it will drain back into the pan w/o lubing anything. It could be as simple as a main bearing without an upper half, or a cam bearing pushed out of its hole, or a decayed plug in a gallery. but until you see it , it won't be fixed. Best of luck, Is there anyone near you to give it a second eyeball? JimN
