Re: Downside to using H head in a 300?
Posted by D Slater on November 25, 2007 at 19:19:43 from (72.65.155.230):
In Reply to: Downside to using H head in a 300? posted by Tractor Tom on November 25, 2007 at 18:32:10:
Don't know if all tractors do, but some 300 with fire craters will hit the H head. If you look at your 300 head you will see the edge on the other side from spark plug is sloped off and the H is not. You can grind that sharp edge on the H head to work if the piston hits. Make all 4 the same and don't go to deep. IH sloped the edge in combustion chamber on the 8043 head when they put it on a SH and advanced the suffix to DD. May not notice any power change.
