Re: ignition switch on instrument panel
Posted by Bob M on November 26, 2007 at 05:54:46 from (151.190.254.108):
In Reply to: Re: ignition switch on instrument panel posted by Monty S. Frazier on November 25, 2007 at 19:36:32:
Sounds like someone put a generic key switch into the ammmeter box. Typically these switches have 4 terminals labelled B, I, A and S.
B = Battery. Connect to the generator side of the ammeter.
I = Ignition. Connect to the coil.
A = Accessory. On a car/truck it feeds the dash gages, radio, heater and other accessory loads. (It's typically not used on a tractor)
S = Starter. Connect to the starter solenoid coil terminal
