Posted by old on November 26, 2007 at 07:48:06 from (4.244.186.117):
In Reply to: Won' t Start posted by negrunke on November 26, 2007 at 04:19:52:
Would help us help you if we knew a little history on what you have or have not done. If you put you hand over the end of the carb does it suck pretty hard on your hand?? If it doesn't then you may have a gasket problem or a manifold leak which would cause that. Does it have gas to the carb?? To check that pull the drain plug out of the bottom of the carb. Try switching the spark plug wires across the cap and see if it runs you may have the firing order 180 out
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
