Posted by Janicholson on November 26, 2007 at 12:22:03 from (199.17.6.122):
In Reply to: Hydraulic System of M posted by WonderingAl on November 26, 2007 at 11:12:01:
Three issues rear their heads: The Older M will have a weak timing gear on the cam (OK for timing, not OK for powering the hydraulic pump. The holes in the mount for the distributor drive housing to front covrer are spaced differently. This requires a later 1951 , or SM front cover/housing, or plugging the existing hole with a soft steel bolt, and drilling partway into it to make new threads for the wider spacing of the SM pump. The M parts will not, as a result of the bolt spacing fit the SM to keep it operating.
Why not use the belly pump on the M for power to run the loader. Less handy not being live hydro, but practical and much less work. JimN
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
