Re: OT...Insulation
Posted by Janicholson on November 26, 2007 at 12:48:52 from (199.17.6.122):
In Reply to: OT...Insulation posted by Dave2 on November 26, 2007 at 12:23:25:
The easiest way is to run your two pipes as described with a single run of Frostex brand heat tape (it can be cut to any length and terminated as needed. It does not need a thermostat at all and just enough heat is applied to keep the pipes at temp, not more. It is the answer to many heat tape questions. Over that, just slip on the foam insulation fron the big box lumberyard of your choice. Much less complex and cheaper to operate. JimN
