I can help some. (I spent many hours driving an "M" as I was growing up) The gear shift pattern goes on the top rear area of the gas tank on the centerline. The O D B is for the light switch if you have a voltage regulator on the generator (means Off, Dim, Bright). If you have a cutout on the generator then you use the L H D B (means Low charge, High charge, Dim, Bright) on the light switch. You don"t need both of those and you should be able to tell which one you need by the number of positions on the light switch (3 or 4). I"ve seen the others you have ? after, but I"ve forgotten exactly where they are placed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
