Re: Super H Live Hydraulics
Posted by chuck46 on November 26, 2007 at 19:04:31 from (64.136.27.229):
In Reply to: Super H Live Hydraulics posted by Matt Weltz on November 26, 2007 at 18:40:09:
Hi Matt, If I have it pictured right, my first question is how will you use the filler pipe? Can you turn the valve 90 degrees then put a tee on the filler pipe so the return will come in the side and there will be a plug on top for measuring and adding oil. When I did mine I mounted two valves together and put them on the right side of the seat, so I didn't need control rods. Good luck, Chuck
