Re: Super H Live Hydraulics
Posted by glennster on November 27, 2007 at 08:48:27 from (76.224.26.7):
In Reply to: Re: Super H Live Hydraulics posted by tmonton on November 27, 2007 at 06:23:54:
yup its a 250 amp dc welder. was sold by a compay called haddican brothers santanta kansas. it uses a bendix p-2 generator from large airplanes. real dang handy. i can zoom anywhere around the farm welding on stuff i break. it dont cut bad either set all the way up on hi.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
