Re: Wheel chains or weights???
Posted by Bob/Ont on November 27, 2007 at 13:55:35 from (205.188.116.73):
In Reply to: Wheel chains or weights??? posted by Aj Clark on November 27, 2007 at 13:34:24:
Chains will bite into Ice and frozen ground and give more traction than weights. You want lots of cross links so you don't slip between them and shock load the drive train. My W6 needs chains to push anything.
Later Bob
