Re: Won' t Start
Posted by El Toro on November 27, 2007 at 17:06:33 from (205.188.116.73):
In Reply to: Re: Won' t Start posted by negrunke on November 27, 2007 at 16:28:25:
That's the way it should be since your rotor turns CW. When No1 piston is at TDC on the compression stroke your rotor should point to the No1 plug tower. You have good suction at the carburetor and is getting fuel. Are you getting a hot blue fire to the plugs? If this is a mag disconnect the grounding wire at the mag for the time being and see if it will start. Hal
