Re: PTO SEAL
Posted by RustyFarmall on November 27, 2007 at 21:26:49 from (66.43.253.19):
In Reply to: PTO SEAL posted by MIKE H on November 27, 2007 at 17:28:13:
Your H originally had just one extra wide seal. Since you removed two seals from yours, the original had already been replaced. If you could compare the original to the new seal, you would quickly realize that it might be a good idea to install two new seals, just like what you removed. Probably a good idea also to pack some grease in between the two new seals because the outer seal will recieve no lubrication otherwise.
