Posted by henryv1111 on November 28, 2007 at 05:33:16 from (64.81.231.196):
In Reply to: Re: M Genertor posted by John T on November 25, 2007 at 18:13:48:
Mr John: Thanks for all the help you have given me in the past. I started the tractor and no charge I checked all the grounds first. I grounded the field and it charged I took the ground off and it worked ok the H/L switch increased or decreased the amp rate ok. after 10 min it quit chariging again. this time I jumpered around the C/O and it started charging again. It looks like the C/O is bad. WIll any 6V C/O work I tried the IHC dealer but they said I have to get a Volt Reg. What ype of C/O is available
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
