Re: SMTA pto leak
Posted by the tractor vet on November 28, 2007 at 15:44:47 from (76.212.232.95):
In Reply to: SMTA pto leak posted by DC5724 on November 28, 2007 at 12:05:22:
the seal on the PTO input is allowing oil from the rearend to enter the PTO and overfilling it . NOw there are two ways to fix this problem , (1) is to remove the PTO unit and replace the seal or (2) add a longer pice of pipe to raise the breather up above the rearend oil level. then when the rear seal starts to leak then ya fix both at the same time . Not the wright way but it works.
