Re: Radiator for a 52 Super A
Posted by Hugh MacKay on November 28, 2007 at 19:53:24 from (216.208.58.98):
In Reply to: Radiator for a 52 Super A posted by Tracy Brown on November 28, 2007 at 18:59:08:
Tracy: I can't comment on the precise part numbers, however I do have some info based on serial numbers. First all tractors over 356001 were Super A1 and the radiator is 2" higher than your radiator, therefor it will not physically fit under your hood.
At serial number 336711 Super A radiators became presurized, thus radiators before and after that number are different. You can switch from presurized to non presurized and vice versa, however your tractor will not be original.
Finally, if I were you, I'd go the recore route, you will get a better product for the money. It will probably cost more than a new rad, however the product will be superion product. Some, maybe most new tractor radiators are coming from Asia, and a lot of those don't fit the sheet metal.
One item you have to watch with all replacment radiators, be they new or recore, the core is different for thermosyphon than water pump appliction.
