Tire change out
Posted by WonderingAl on November 28, 2007 at 21:56:34 from (66.32.146.2):
Farmall H tractors. The bolts holding the rim/tire onto the wheels are frozen on something bad and I want to switch out to another tire/rim set...would it be easier to remove the wheel/rim/tire altogether of heating bolts and trying to go that route? What would be the best method if a person had one day to switch out four tire/rims?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
