Posted by randy47 on November 29, 2007 at 07:24:45 from (64.108.154.232):
I have an A Farmall the engine was completly overhauled 2 years ago and only has about 30 or so hours on it since then it mostly sit but has always started and run very good. Today I started it and can only get alittle more than an idle -- Ive cleaned the carb adjusted the valves and changed plugs but still no move than an idle --- the govner linkage moves freely -- if I move the govner arm while it run nothing changes. WHAT NEXT !!!!???
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
