Posted by Satisfied 384 owner on November 29, 2007 at 13:09:52 from (199.243.50.182):
In Reply to: IH 384? posted by MF Poor on November 28, 2007 at 05:10:07:
You have likely made up your mind about the 384 already. But thought I would add my $.02
We like our 384. While we were looking for a Hydro - this one works well for us. We have an IH 1850 loader mounted to it - and it works well. It can be a little awkward to get on and off, especially with a loader as you can only dismount from the left side. What also "can" make it awkward is the fact that the gear shift and Hi-Low levers are right between your feet. There is a plus to that though. If you are doing loader work , reverse and 1st are right in line with each other. It is not a shuttle shift, but it makes for a fairly quick cycle.
Tractor has ample power to run loader. This summer we were plowing VERY hard ground with an IH 36 3f plow mounted to it - handled it no problem. It is the smallest tractor on the farm and it is a good utility tractor.
Up north, here in Canada, we find that the glow plugs DO actually help starting in the winter - no problems there. Parts - easy to get. I replaced #1 fuel line this fall (simply preventative maintenance) and the part was in the area depot.
Prices - they can run anywhere from $7995 -$10,000 CDN dollars easily esp. with a loader.
Good luck with your decision.
mark
PS: Speaking from experience, don't run it out of fuel. It does take two people to bleed and prime the fuel system.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
