Re: Hand crank storage 1940 H
Posted by Janicholson on November 29, 2007 at 14:35:53 from (66.173.50.69):
In Reply to: Hand crank storage 1940 H posted by tackhammertime on November 29, 2007 at 14:26:35:
The answer is complex but not over taxing.
There is no place on the tractor that is "THE" place. Many make a set of clips to hold it on the frame rail under the carb, Others just hang it in the frame rail in a position that it can't fall from, some put it on the platform loose, some on the platform with velcro, or a clip or two. The most common solution (probably in the 80th percentile is choosing a nice dryish place in the barn that is between studs, or behind that never moved future project that cannot be tossed, and there it stays. Ours are in the garage behind the work bench. JimN
