With respect and concern for safety, I must seriously disagree with your assessment of kickback. The lube of the shaft (though making it easier if not possible)has not a thing to do with kickback. Advanced spark timing, causing the cylinder coming up to fire before TDC, causes the engine to turn backwards violently. This twists on the handcrank drive mechanism in the same "drive direction, but opposite rotational direction. That crank arm will come around on you so fast that you cannot get out of the way.
Make dead sure of the timing. Put the crank in at the bottom. Pull up only 1/2 turn, do not spin ever. Keep your thumb and all fingers on the right hand side of the crank handle. Keep your body arms and face out of the rotational possible locations of the handle as though it were making 360.
The place for the crank is fine on the right side, but, even if you have been unhurt, the info could be dangerous. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
