I think some of the manuals say to push the switchover lever down or back for starting on gas. I think that must be for the W series or is a misprint. All that I have ever seen, (and on the one I own) you push the switchover lever forward. It should stay there on it's own. If it does not, something in the linkage is messed up. So to start, switchover lever forward and the diesel speed control lever all the way down in the shut off position. Mine takes full choke to start and then you fiddle with the choke to keep it running. Rarely takes more than two turns to start. After warming for a couple of minutes, pull back the starting lever and advance the diesel speed control at the same time. If the engine is warm enough and all working as it should, it should then be running on diesel.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
