Re: breaking a froze moter on a a
Posted by glennster on November 30, 2007 at 08:21:59 from (76.224.26.7):
In Reply to: breaking a froze moter on a a posted by jerry s on November 30, 2007 at 08:07:10:
the way i do em, pull the oil pan drain plug, drain everything out. put plug back in. remove spark plugs, fill the cylinders with pb blaster, (buy the gallon jug.) then pour the rest down the oil fill hole. let the tractor set for a week. end of the week, put trans inn high gear and rock the tractor back and forth, see if it loosens up. if not do again. other guys here like to use automatic trans fluid, it works for them. w-d 40 is not a good penetrant.
