Re: breaking a froze moter on a a
Posted by gene bender on November 30, 2007 at 10:51:37 from (67.55.226.214):
In Reply to: breaking a froze moter on a a posted by jerry s on November 30, 2007 at 08:07:10:
Since you are goimg to replace the seals save the money on anything to loosen the pistons. Remove the engine from the tractor and put it on a engine stand. You will be able to remove the crank and have it checked as it mite need to be ground. Then you can remove the sleeves with the pistons in the sleeves. You then should be able to press the pistons out the bottom of the sleeves. I just finished tearing one down that way and will push the pistons out the bottom. Good luck you have some work to do.
