Re: OT chainsaw won't cut straight
Posted by Dave BN on November 30, 2007 at 14:33:44 from (64.12.116.73):
In Reply to: OT chainsaw won't cut straight posted by riverbend on November 30, 2007 at 12:35:22:
Yep, take it to the sharpening guy or buy a new chain or both. If you look you'll most likely find that the tops of the teeth are rounded off. If so,to properly sharpen that chain will require removing a lot of each tooth. Thus your chain will not have much life left and the depth quages will need filing also. I save one old chain to use for doing just what you were doing and cutting dirty wood, roots etc. No sense in ruining a new/good chain. Dave.
