The problem is that you don't know why its stuck. we all assume that it's pistons, but it could well be several other things. For instance I had an Allis B engine stuck and we towed it gently to try to loosen it and it was only a valve stuck closed.(Bent the push rod).If it won't free easily with a GENTLE pull then maybe you lose nothing by stripping it. MTF
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
