One side is still dull. Look at the side of the chipper, there will be a worn triangle shaped dull place in it. This takes the set out of the chain and the tooth rubs instead of cuts. The length and angle doesn't have to be perfect but it has to be sharp. The less angle you have on the tooth, the narrower the kerf. Good for hard woods, the sharper the angle, the wider the kerf, good for soft woods. Try to keep both sides the same length and angle. Once you get the dull out sharpen the other side to the same length. If the worn abrasive angle goes too far back on the tooth it is probably better to get a new chain as it can take a lot of filing to get it right. After you get it sharp, be sure to cut the drags down also. This sets how deep the tooth will cut in the wood.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
